Janice9
Message 1 of 5
Incoming UK numbers appearing as international on phone
Since I installed my new Virgin sim, all coming calls are showing in wrong format and telling me they are international. What can I do?
Natalie_L
  • 2.66K
  • 120
  • 231
Message 2 of 5
Re: Incoming UK numbers appearing as international on phone
Hi Janice9,
Welcome to the Community and thank you for getting in touch.
Our apologies for the delay in response.
I have taken a look and this issue seems to appear mainly on iPhones, is this the case for you please?
Nat
Janice9
Message 3 of 5
Yes, I have an iPhone but the iPhone community tell me it is a carrier issue not a phone issue
enlli
  • 7.42K
  • 1.18K
  • 2.1K
Message 4 of 5
This should fix it
Goto
Settings -> mobile data -> SIM Applications (near bottom) -> tap "Roaming"  -> tap "Select Mode"
I found "automatic" was selected by default.
Tap manual -> then choose National.
If National is not there choose Virgin
Reboot the phone afterwards
Janice9
Message 5 of 5
Thanks - have done this and changed to Manual - will have to wait for a non iPhone call now to check if it's worked
