on 11-05-2023 08:48
Your robot has already replied as if I was in the UK - that solution does not work.
Others have had pin sent by text when abroad, please do the same - send a pin for me by text
on 11-05-2023 09:00
Hi @russtheking 👋.
Thanks for your post, in order to look into this we would need to send you a private message. Please look out for the envelope on the top right, or should you be using a mobile device, it will be under you profile icon.
Thanks.
Sabrina
on 11-05-2023 17:34
If I am still emailing with a robot, 'Sabrina_Bot', could you put me across to a manger at Virgin Mobile. As I would like to share my problem, which is easily shared, with someone who can feel my pain.
I have opened the envelope as instructed, but it doesnt help me.
Can your manager send me a text with a pin for voicemail - remember I am abroad at the moment. I see it has worked for others who have had the same problem.
on 11-05-2023 17:37
Hi @russtheking
Thanks for your response
My colleague certainly isn't a BOT and if you respond to the private message they have sent they'll look to get this resolved for you.
on 11-05-2023 17:42
OK, I have clicked onto the envelope at the top of my screen, on my PC
What happens next?
on 11-05-2023 17:43
Hi @russtheking
I can see my colleague has private messaged you successfully, a message should be there from Sabrina_B which you can load up and reply to from the inbox
on 11-05-2023 17:47
When I look at my inbox, all I get is yesterdays
on 11-05-2023 17:50
Hi @russtheking
Are you able to check your inbox for me to see if the message has been accidentally deleted? I have contacted my colleague to resend the private message for you so we can get this resolved for you as soon as possible 🙂
on 11-05-2023 17:56
I am looking at the 'inbox' on the top left hand side of my screen after clicking on the envelope icon on the top rright of my screen
on 11-05-2023 18:31
Hi russtheking,
We're sorry to hear you're having further issues. I think it would be best if I just re-send the message for you.
If you are using a PC/Laptop then you can just click on the little ✉ at the top right-hand side of the page to access your inbox. If you are on a mobile/tablet device then instead click on the little circle icon in the top right then select 'Messages'. This will then load your inbox up and my message should appear for you. 😊
