Micka
  • 22
Message 1 of 5
Huawei P smart
Hi, not sure if anyone can give me advice, I have a Huawei P smart phone which is now out of contract. I have ordered a new Sim from Virgin at a cheaper rate. It states on the contract the phone must be compatible for 5g and I’m unsure if it is. Would it still work if it wasn’t?
David_Bn
  • 8.54K
  • 359
  • 664
Message 2 of 5
Re: Huawei P smart
Thanks for your post @Micka.
Sadly the handset would need to be 5G compatible.
There are three elements required to work on a 5G service;
1) The SIM and tariff are 5G
2) The mast you're connecting produces a 5G service
3) The handset is compatible with 5G services
Kindest regards,
David_Bn
enlli
  • 9.51K
  • 1.43K
  • 2.74K
Message 3 of 5
Re: Huawei P smart
The phone only needs to be compatible with 5G to work on the 5G service.
If not it will happily work on 4G 3G and 2G even with a 5G SIM. Let's face it no everywhere has 5G
Micka
  • 22
Message 4 of 5
Re: Huawei P smart
Thanks David Bn, so would i be still able to use the phone on 4g/3g
Micka
  • 22
Message 5 of 5
Re: Huawei P smart
Thanks Enlli
