22hansell
Have a problem losing my phone/message signal intermittently.
Have a problem losing my phone/message signal intermittently. Take Sim card out, wipe it and put it back and all is ok for some time. Is it the card or the phone?
Megan_L
  • 2.76K
  • 166
  • 295
Re: Have a problem losing my phone/message signal intermittently.
Hi 22Hansel,
Thanks for using the forums to get this issue with your mobile/SIM looked into, I am sorry if this has been causing some frustration. I would be more than happy to look into this for you.
Can I ask if you've got a spare phone you can test the SIM card in? If the issue does not occur in the other phone then this is a good indicator that it is your handset that is the root cause. if it does occur in the other phone then it will more likely be the SIM card - we cant send out replacement SIM's when this is the case 🙂
Can I also ask if you get any error messages when the network drops please?
Megan_L
22hansell
Thanks Megan. Spot on with your suggestion and, yes, SIM card fine and handset the problem!
Very good of you to reply.
Best Adrian
Megan_L
  • 2.76K
  • 166
  • 295
Hi 22Hansell,
Thanks for your reply 🙂
I am glad my advice helped you figure our what the issue was! Just as a side note, I see I have done a typo in my previous post. Just to make sure you know we can* send out replacement SIMs here on the forums! 🙂
So if the issue occurs again in a brand new handset, just pop back here and we can investigate further and send a new SIM out.
Thanks so much!
Megan_L
