Going to USA
Lancecw
Hi I'm going to the USA for 4 weeks I have a contract that is unlimited everything as I read it none of this is of any use why I'm in the USA is there anything that's going to be a reasonable amount of money that I can add on to be able to use my phone in the USA or would you recommend I get a SIM card when I'm out there be grateful for any advice
2 REPLIES 2
dannylau
You can buy data packs, personally I find everywhere in the US has WiFi and that's enough for everyday use and I simply turn my data off
Hayley_S
Hello @Lancecw,
Welcome! Thanks for posting.
I can see @dannylau has already given you a brilliant answer, you can buy data packs but Free Wi-Fi is always a good idea also.
Many thanks,
Hayley
