Antonymarsh1
Going on holiday
Are there roaming charges when I go to the canaries
enlli
  • 9.52K
  • 1.43K
  • 2.74K
Re: Going on holiday
Part of Spanish territory, so no.
Travis_M
  • 3.89K
  • 140
  • 287
Hi @Antonymarsh1
Thanks for posting on our community forum!
You are able to roam like home in the Canary Islands which mean you can use your plan exactly as you would here.
Travis_M
