on 05-08-2022 16:19
I want to extend the length of time my phone rings to 30 seconds, before it goes to VM. I have been on to Customer Care, and the details they gave me do not work.
I have a Samsung Galaxy A40.
Help please!
on 05-08-2022 16:22
On a lot of Samsung phones you need to switch off WiFi and 4G and make sure the code goes over 3G/2G
on 05-08-2022 16:26
Hi llewis
Thanks for posting. Please see here - https://www.wikihow.com/Change-Number-of-Rings-on-Samsung-Galaxy - how to do this
Best,
on 05-08-2022 16:31
Tried it - doesn't work.
on 05-08-2022 16:33
Doesn't work
on 05-08-2022 16:56
Thanks for coming back to us. Please contact the manufacturer directly - https://www.samsung.com/uk/support/contact/
Kind regards,
on 05-08-2022 16:59
What are you entering.
**61*+447458333222*11*30#
Has just worked here.
on 20-05-2023 16:55
Thank you. It needed the extra *s before and after the 11. Brilliant.
