kevino81
  • 156
Message 1 of 10
Error 500 when sending texts. Phone keeps cutting out too
Anyone had this,
Error 500.
On the phone it struggles to keep a connection.
Pulled the sim out and back in again but didn't help.
Had the phone for more than 2 years.
Ashleigh_C
  • 3.74K
  • 152
  • 288
Message 2 of 10
Re: Error 500 when sending texts. Phone keeps cutting out too
Hi there @kevino81
Thank you so much for your post and I am so sorry to hear that you have faced this issues with your text message services!
Are you able to make and receive calls OK? Also have you been able to try the SIM in another handset or another SIM in your current handset to see if the error replicates?
Thank you.
Ash_C
kevino81
  • 156
Message 3 of 10
The calls are working at first but then the cut out while I'm talking to people.
The text usually goes through if I keep trying it.
Nothing worse than an intermittent fault.
Not tried the sim in another phone but I don't have one.
What is error code 500??
Robert_P
  • 4.4K
  • 206
  • 399
Message 4 of 10
From the image provided it appears the handset is connected to a wireless network, do you experience the same problems when using the mobile network?
Can you also try this in different locations to see if it is area specific or everywhere?
Rob
kevino81
  • 156
Message 5 of 10
Virgin say there is network problems in my area.
My texts and calls do not use wireless network or wi fi.  Shud just be the coverage should it not??
Zak_M
  • 6.12K
  • 315
  • 545
Message 6 of 10
Thank you for coming back to us @kevino81
Are the issues persistent when you are in different areas or is it just specific to one?
Kind regards,
Zak_M
kevino81
  • 156
Message 7 of 10
Tried it in England and in Scotland.
Data slow
Texts tepremental
Phone calls cut out.
On WiFi the phone is fine on Internet.
Natalie_L
  • 5.13K
  • 195
  • 399
Message 8 of 10
Thank you for your reply kevino81.
Have you been offered a Sim replacement at all?
Nat
dewi15dewi
Message 9 of 10
Hi Nat, I am having the exact same issues as kevino81.  My phone signal goes on and off all the time, it will not connect to any mobile data but can make calls and also Whatsapp messages do come through sporadically.  I was sent a new sim card which I have registered but the problems remain.  i have just tried to send a text message and got the error 500 code.
Please help.
Gareth_L
  • 10.32K
  • 581
  • 1.15K
Message 10 of 10
HI dewi15dewi
Sorry this is happening to you after receiving a new sim
When did you receive this and how long after did the error appear
Gareth_L
