Char101
Dubai data roaming
I’m off to Dubai on Monday but I don’t have an option on my phone to turn off data roaming. I obviously want to avoid these charges but don’t know how to switch it off because it’s not in my settings. Also if I wanted some sort of data roaming allowance how do I go about it? I can never get in touch with someone from virgin.
g0akc
  • 2.04K
  • 161
  • 386
Problem sorter
Re: Dubai data roaming
What phone do you have?
I know a bit about Wi-Fi, Telecoms, and TV as I used to do it for a living but I'm not perfect so don't beat me up... If you make things you make mistakes!
enlli
  • 9.81K
  • 1.45K
  • 2.82K
There are no add on data roaming packages on Virgin
Ashleigh_C
  • 5.3K
  • 194
  • 387
Hi there @Char101
Thank you so much for your post and welcome back to the forums.
Just wanted to pop in and confirm that @enlli is correct and we do not have data roaming packages, but we can look into turning this off for you.
I will send you a PM now so we can arrange this.
Please keep an eye out for the purple envelope in the top right corner of your screen.
Thank you.
Ash_C
