AngelaCN
Default network for phone calls
When making phone calls the phone defaults to wifi. I want to change the default to 4g - how do I do that?
enlli
  • 7.39K
  • 1.17K
  • 2.08K
Re: Default network for phone calls
Do you have WiFi Calling? If so you can turn it off on your phone.
You can't use 4G to make calls on Virgin only 3G 2G so check that you have coverage on both of these.
