RomseyRambler
  • 101
  • 9
  • 20
Up to speed
Message 1 of 8
Deactivated SIM and number STAC'd. HELP!
Morning
I have requested my number be STAC'd as I no longer wish to have my old number.  I received my VM SIM card and was told it would be active on Monday (today).  However when putting the SIM in it is saying Emergency Calls Only.  I have just called and the SIM I have is deactivated!.
Is there any way of getting a new SIM out faster than 3-5 days?  My old number is now not active and Im now without a VM sim/number so have no way to communicate for 3-5 days.  The nearest VM store is an hours drive away.  Please can a card be sent out 1st class?
zokansal
Just joined
Message 2 of 8
Re: Deactivated SIM and number STAC'd. HELP!
i think you should wait to Monday to end to active your SIM, i think that man be patient
افضل شركة وساطة مالية في السعودية
RomseyRambler
  • 101
  • 9
  • 20
Up to speed
Message 3 of 8
In hindsight yes..however I was told on the phone by VM that my VM number wouldn't activate as I had requested a STAC.  Was told it would work today..old number gone so thought "ok so VM now works"....nope completely dead and deactivated SIM 😞
RomseyRambler
  • 101
  • 9
  • 20
Up to speed
Message 4 of 8
Absolutely fuming mad!!! I was told by an analyst at VM if I go to a Virgin Media shop they could get the SIM for me.  I have just spent the last hour driving to a store to be told "the Order for the SIM has gone through, so we cant swap it". I cannot believe how unbelievably difficult it is to get a SIM card.  What happened to the days of cancelling one and activating another.
I even asked if the number could be cancelled if it meant I could get one at the store however I would have to go through another credit check!  I am absolutely fuming at VM now.  I am a new customer and dont even have my services installed yet, I am seriously contemplating going back to Sky and putting up with the useless Broadband if it means I get some sort of straight answer and service.
RomseyRambler
  • 101
  • 9
  • 20
Up to speed
Message 5 of 8
Chris has kindly come back to me on this. Thanks Chris. I hope to get this sorted asap.
Runchie
Just joined
Message 6 of 8
I had the same problem with VM and right now none is able to call or whatsoever I have been asking for my pac code since the third of December on the 10th they deactivated my sim and now telling me I can’t activate my sim hence I can no longer can a pac code . Vn are the worst
enlli
  • 8.05K
  • 1.26K
  • 2.3K
Message 7 of 8
@Runchie
This thread is 2 years old.
If you have a problem please start a new topic
Lee_R
  • 3.95K
  • 189
  • 397
Message 8 of 8
Hi @Runchie.
I am sorry to hear you're having issues with retaining your number.  Has it been confirmed the mobile number in question has been lost forever?
Lee_R
