Skills88
  • 5
Data usage whilst roaming eu
I am a bit confused by VM sim only tariffs.
Essentially I need to know whether my monthly allowance of data will also be available if travelling within the eu.
Tags (2)
DJ_Shadow1966
  • 6.85K
  • 1.31K
  • 1.89K
Re: Data usage whilst roaming eu
Hello
Yes your data allowance is usable when you are in the EU, just like when you are in UK all the info is https://store.virginmedia.com/virgin-media-mobile/our-mobile-network/data-roaming-abroad.html
Regards Mike
