Steff1968
  • 11
Data speed drops dramatically.
My phone speed seems to have slowed down dramatically over the last few months.
Have tried everything I can think of to correct.
Was getting constant 80Mbps.. Now dropped to around 8-10 and even much less a lot of the times.
Upload speeds are dreadful also
To try and fix this I called Virgin and was connected  somewhere abroad.. They sent a new sim but that made no difference.
I have reset my phone... ran updates Rolled back to older versions etc.
Checked speed of another device.. someone with the same model and using virgin network was getting the speeds I used to get so it doesn't seem to be the signal.
 I check speed outwith my work and home area which is a mile apart BTW.. I seem to get much faster connections.
So it seems its my phone it this one area.
Have tried various APN settings also
Any ideas
enlli
  • 7.4K
  • 1.17K
  • 2.08K
Re: Data speed drops dramatically.
You may have been moved over to Vodafone as part off Virgin's move to a new signal supplier.
Do a manual network search. If EE is visible but Vodafone is missing that is what has happened
Steff1968
  • 11
Yeah...
No Vodafone listed.
Thanks for the info and heads up
How can I get put back on the connection I was before..if that is possible.
Its obviously still available as the test with a co-worker showed the much higher speeds.
Thanks Again
enlli
  • 7.4K
  • 1.17K
  • 2.08K
As far as I am aware from team postings the migrating process cannot be reversed. In the next 6 months all customers will be transferred to Vodafone as Virgin's contract with EE ends.
Steff1968
  • 11
Yeah... That's what I thought.
Will have to look elsewhere then.
Thanks again for your help.
Megan_L
  • 2.67K
  • 161
  • 279
Hi Steff1968,
Thanks for using the forums to get this issue with your mobile data looked into, I am sorry it's become quite slow over the recent weeks/months.
Enlli's advice is correct, we have started a migrating process and all customers will be on the new network by approximately the first quarter of next year.
Can I ask if you're still within contract please? If you are, there may be a Buyout Fee attached to your cancellation (monthly cost x how many months you have left) I just wanted to make you aware of this so you don't get a surprise when you call our mobile retentions team!
If you need more help or advice, please feel free to reply and I will be more than happy to help 🙂
Megan_L
