zabuza88
Data speed down to 5.71mbps at work and 9.72 at home. Apparently suppose to be 37mbps - what the heck?
Pretty much the title. I’ve had so many issues with this the last few weeks and it’s driving me mad. At work, I have zero signal, no bars, no data. It’s putting strain on my work as I can’t communicate with anyone unless I leave the building and cross the road (there is no WiFi). Contacted virgin, was told to try a download which hasn’t worked. They’re sending a new SIM card (which is 4 years old) and that’s the next try but the issue is on another SIM card as well that is only a few months old so I don’t think that’s the issue.
Has anyone got any idea what could be going on? I’m fed up of being cut off from the rest of the team because of crappy service.
Akua_A
  • 4.76K
  • 123
  • 324
Re: Data speed down to 5.71mbps at work and 9.72 at home. Apparently suppose to be 37mbps - what ...
Hi @zabuza88
Welcome to our community forums and thank you for your first posts.
Sorry to hear you are having issues with your data speeds. We can understand the frustration caused and want to best help. Just to clarify, does this only occur when at work? How is service elsewhere? Are you able to confirm what network you are connected to when at work?
Akua_A
jb66
  • 13.01K
  • 991
  • 1.95K
Re: Data speed down to 5.71mbps at work and 9.72 at home. Apparently suppose to be 37mbps - what the heck
If you dont get a good signal from your provider then your only option is to move to another mobile provider which meets your signal needs
enlli
  • 9.83K
  • 1.45K
  • 2.82K
Probably coincides with the move to Vodafone from EE.
Still at a loss to understand why Virgin on Vodafone often have slower speeds the Vodafone users in the same location though.
