on 23-04-2023 11:30
Help please
I've tried to delay the voicemail to 15 seconds using the code
*61+4474583332221115# and also *61+447458333222**15#
Neither code works, nor **61*+44795322222**15# as suggested by another virgin website.
Any other suggestions please as this is all very frustrating
Thanks in advance
on 23-04-2023 11:34
Hi @tonycat0
Thanks for posting on our community forum and sorry to hear about this issue.
What error message are you getting when you try to dial the code provided?
on 23-04-2023 11:37
Thanks for replying
'Connection problem or invalid MMI code'
on 23-04-2023 11:50
Hi @tonycat0
Thanks for response
Just to double check, are you in the UK currently? As this may be affected if abroad 🙂
on 23-04-2023 12:01
Yes I'm in Nottingham.
on 23-04-2023 12:56
I'm going to pop you over a private message to check on a few details to make sure Voicemail is fully active, please keep an eye on your inbox for a message from myself @tonycat0 🙂
on 23-04-2023 15:22
I've checked and voicemail is working fine. So far no private messages though.
