I'm on Virgin mobile. I couldn't get the coverage checker to work initially but since have and I'm apparently in a low signal area. I cannot believe I was previously as have never had any issues before, and I was never told there was a change or that my signal strength would be low. I've been with Virgin mobile for a while now and never had this issue before.
For reference my postcode is RM16 2DU.
