  • 8
carged
Message 1 of 1
Captcha Issue SOLVED!!!!!
Hope this  helps anyone  else out there having issues getting past the  captcha login  for registering mobile phone.  After many failed tries I called Virgin Media 03454541111 and explained the problem. The person on the phone  started to go through all the things I had already tried. I interrupted  and asked if they could do it for me. Low and behold after about  three minutes he had set up my account  for me and its working!!!! Very helpful, but apparently  you have to ask them to set it up  they cant offer to do it. Good luck people  hope this works for you all. 🙂
ps  you may have to wait 24 hours if you have failed attempts  as it locks your account  before they can set it up .
