Adamsaxeman
Message 1 of 8
Cant use data in Belgium tried everything help
I think ive tried everything, it  worked intermittently when i first arrived at ferry terminal  now nothing
Kain_W
  • 3.69K
  • 102
  • 263
Message 2 of 8
Re: Cant use data in Belgium tried everything help
Hello Adamsaxeman,
Thanks for your post and welcome to the community.
Can I ask what phone model you have?
Let us know,
Kain
Adamsaxeman
Message 3 of 8
Hi its a i phone SE 2020 model
My wife has same phone and is also with Virgin but has no issues
Kain_W
  • 3.69K
  • 102
  • 263
Message 4 of 8
Thanks for the response there,
Can I ask are you able to run through these settings?
Select Apps from the Home Screen
Select Virgin SIM Toolkit Icon
Select Roaming
Select Mode
Select Manual
Select International-you are done, go back to Home Screen
Let us know if this works,
Kain
Adamsaxeman
Message 5 of 8
no we both dont have this on either of our phones
paulchambers061
  • 2.43K
  • 264
  • 462
Problem sorter
Message 6 of 8
Try this
Settings > Mobile Data > SIM applications > Roaming > Select Mode > Manual > International
Reverse that last step when you return to the UK (if that works)
Adamsaxeman
Message 7 of 8
no That didn’t work, I’m afraid
Matthew_ML
  • 3.53K
  • 131
  • 238
Message 8 of 8
Hey Adamsaxeman, thank you for reaching back out.
Okay, this should have worked for you.
As this didn't I am going to send you a PM, so we can look into this for you.
Please out look for the purple envelope. Thanks
Matt - Forum Team
New around here?
