on 06-04-2023 09:41
I've tried everything suggested but without this sim toolkit app it appears I am screwed whilst here.
on 06-04-2023 10:16
Without the SIM Toolkit you are sunk
You will be asked to try lots of things from A to Z but posts on here over the past 2 years will show them to be futile.
on 06-04-2023 10:45
Hi there @Rey2 👋 Welcome to our forum and thanks for your post 😊
Sorry to see that you are having issues with using your connection abroad, I have checked on our end and there doesn't seem to be any known issues with roaming that we know of. I would recommend checking our roaming hub here for further help with this.
If you need any support after trying this, please let us know. We'll be happy to assist.
Nathan
on 06-04-2023 11:58
Thanks. I have checked out all of the steps suggested and nothing works.
on 06-04-2023 12:10
@Rey2 Do a search for Guernsey on the forum. Will tell you all you need to know
on 06-04-2023 12:34
Thanks for checking that for me, as this has not worked I will be happy to look at this further for you.
I'll send you a PM to confirm your details so this can be done.
Nathan
