I am roaming in Fuerteventura and can’t receive incoming calls. The phone rings but when I answer the caller can’t get through. I can call out and send and receive text just no incoming calls ???
I am sorry you are having issues with your mobile roaming, have you switched roaming on and off from your mobile account, and turned your device on and off?
Sorry to hear this, I can take a look for you on our end to see if there are any issues, I will pop you over a private message and we can go on from there, just keep an eye out for the purple envelope 🙂
