adyjl
Can’t receive incoming calls on 4g
Living in the Stoke-On-Trent area my wife and I can suddenly not receive incoming calls at home. It appears to be related to network switching. As I understand it, when a call is received the handset switches from 4g to 3G. If I call my iPhone from my wife’s galaxy s9, I see the 4g change to 3G but then the call fails. The message saying this phone is turned off or unavailable. Sometimes it will continue to give a ringing tone to the caller but no sound or sign of a call is seen at the receiving end. Shortly after the iPhone will switch back to 4g again. This is repeatable behaviour. If I switch off 4g or switch off mobile data altogether I can receive calls without issue. This is hardly satisfactory as I am paying for 4g. If I need to turn it off to use the phone then I am effectively paying for something I can not use. This issue is affecting both devices in exactly the same way.
teabag
  • 5.77K
  • 802
  • 1.65K
Hero
Re: Can’t receive incoming calls on 4g
That sounds like a very old problem which has done it's rounds on various masts in last couple of years 🤔
https://community.virginmedia.com/t5/Virgin-Mobile/Unable-to-receive-calls-on-4G/m-p/3925474
BB 200 - Hub 3, Phone Talk w/ends, Mobile Sim only. Customer since 1993.
enlli
  • 7.36K
  • 1.17K
  • 2.08K
This has cropped up from time to time and seems to be down to the EE network in places.  Easy to check if you can try in a location away from where you have the problem
Don't know the outcome of the other complaints as nobody seems to have come back to say it's fixed: I assume it has.
Assume EE are reporting all OK. Still, worth a check.
https://myaccount.ee.co.uk/networkchecker/checkservice
