Can’t hear calls. Incoming or outgoing.
Zanwbu99
I’ve put my old sim in a new phone but it can’t hear any calls going out or coming in and the person on the other line can’t hear me either🥲
1 ACCEPTED SOLUTION
Accepted Solutions
As the sim works on your old phone and you've tried 2 sims in your new handset and you get the same issue, this indicates the issue is with the handset @Zanwbu99
We would suggest getting in contact with the manufacturer.
Let us know how you get on.
Ayisha_B
19 REPLIES 19
Ilyas_Y
Hi @Zanwbu99, thanks for reaching out to us and a warm welcome to the Virgin Media Community Forums. 👋🏼
I'm sorry to hear about the issues with the SIM card in the new phone. 😞
May I ask if the same issue occurs when you put a different SIM inside the new phone?
Let us know.
Kind regards,
Ilyas.
Ilyas_Y
Hi ilyas,
 the issue doesn’t occur when I put it in a different phone
Sorry I replied wrong. I haven’t tried that yet.I’ll try it and get back to you.
Thanks for the reply @Zanwbu99 on the forums.
And no worries!
Let us know how it goes and we can go on from there.
Kind regards,
Ilyas.
Ilyas_Y
Hi ilyas,
 I’ve tried with a different sim and I’m having the same issue
Thanks for the reply @Zanwbu99 and for the update!
So this would indicate it is an issue with the device then if multiple SIM cards are not working on the new handset.
Please get in touch with the manufacturer.
Kind regards,
Ilyas.
Ilyas_Y
Hi Ilyas,
Will do. However this isn’t an issue with FaceTime or WhatsApp calls. Just phone calls made through the sim.
I should also let you know that this phone is 5G and my sim is 4G. Would that affect it?
So the Facetime feature and WhatsApp are all linked to the account on the device, which would have been verified through the SIM previously or transferred over with the iOS capability.
Are you able to check your network settings and connect to the network manually rather than automatically?
Kind regards,
Ilyas.
Ilyas_Y
