  • 15
Calls
i have a samsung A50,When i'm calling a company and they ask me to press the relevant number/s,l can only give the numbers,l can't find a way to give the letters.
  • 5.84K
  • 924
  • 1.62K
Re: Calls
Not sure what is going on. If you are in a call and have to send numbers via dial tones, fine. I've never heard of a method of sending letters that way.
  • 5.72K
  • 800
  • 1.63K
Hero
Re: Calls
For when I have used ones which require letters - like entering letters from passwords, it is usually press the number which contains the letter. ie: pressing 1 covers ABC, 2 covers DEF ect.
BB 200 - Hub 3, Phone Talk w/ends, Mobile Sim only. Customer since 1993.
  • 15
Re: Calls
Thanks,my son say's the same thing
