  • 6
PKY51
Message 1 of 7
Call Forwarding
I cannot activate Call Forwarding on my Virgin J3 to 04182 665023 - WHY?
  • 201
  • 24
  • 40
Enceladus1
Superfast
Message 2 of 7
Re: Call Forwarding
Are you sure you have the number correct? The area code 04182 doesn't seem to be valid.
  • 6
PKY51
Message 3 of 7
Re: Call Forwarding
Oh dear - it should be [Number Removed] - [Hull area code]
  • 2.34K
  • 50
  • 69
Moderator
Moderator
Message 4 of 7
Re: Call Forwarding
Hi there PKY51, thanks for your post.
At the moment we currently don't support call forwarding to a landline which would be why you have been unable to set this up.
Nathan B
Quolh
Message 5 of 7
Re: Call Forwarding
Nathan_B, your reply suggests that whilst call-forwarding to a landline is not possible call-forwarding to another mobile is.
Is that really the case?
  • 3.54K
  • 484
  • 937
Message 6 of 7
Re: Call Forwarding
To my knowledge there is no call forwarding to any phone on Virgin and only forwarding to VoiceMail.
Just try putting in a mobile number, I think you will find it will fail.
Click to learn more about VIP
Use Kudos to say thanks
Quolh
Message 7 of 7
Re: Call Forwarding
Tis true. Sadly and annoyingly!
