gerikelly
After PAC received
Hi. I asked for and received my pac from VM about two weeks ago and gave the code to my new provider.  However the contract with new provider wont start for about 10 days.  Can I continue to use my VM sim until then?
enlli
  • 7.01K
  • 1.11K
  • 1.97K
Re: After PAC received
Your new supplier should give you a transfer date nearer the time. Up till then you can use your Virgin phone.
Remember though that you pac has to be actioned within 30 days of issue.
