WG1316
  • 32
Message 1 of 17
APN Settings
I have been looking up APN settings online, including this one: Virgin 4G LTE APN Settings 2022 - 4G APN Settings
My settings include many fields that are "Not set".
I have been experiencing 'Refreshing SIN data' messages and wonder whether it has something to do with WiFi Calling, and whether the LTE that appears when wifi calling is active (or after it has dropped and reappears eventually as an option to switch on) is responsible for my phone dropping the wifi connection.
Can someone tell me what the APN settings should be.
As a second line of thought, I asked for a PAC code in mid-january and received one, however I did not use it. It is around that time that the 'Refreshing SIN data' message started appearing and wifi calling started dropping out on my hub at my place of residence.
Lastly, anyone know whether Virgin's wifi calling feature has been updated during January this year?
enlli
  • 9.81K
  • 1.45K
  • 2.82K
Message 2 of 17
Re: APN Settings
These settings work for most Android.  I'm sure iOS is similar
Internet & MMS APN.
APN: goto.virginmobile.uk
MMSC: http://mms.virginmobile.co.uk:8002
MMS proxy: 193.30.166.2
MMS port: 8080
MCC: 234
MNC: 38
Authentication type: CHAP
APN type: *
APN Protocol: IPv4
APN Roaming Protocol: IPv4
Leave all other options blank/Not set
WG1316
  • 32
Message 3 of 17
Re: APN Settings
Thank you.
I have worked out that my phone is not saving the settings.
Tom_W1
  • 3.66K
  • 199
  • 343
Message 4 of 17
Re: APN Settings
Hi @WG1316, thanks for your post here in the community.
Now you have worked out that your phone isn't saving the settings, can you please confirm if you require further assistance regarding this matter
If you didn't action the PAC Code, then this does just become invalid and shouldn't really impact anything regarding your device or wifi calling.
We also haven't updated our wifi calling features recently, but please let us know if you require any further help.
Many thanks
Tom_W
WG1316
  • 32
Message 5 of 17
Re: APN Settings
If you know it, can you provide me with the number I can use to text to, in order to receive the configuration settings text (in return)?
I have also received a 'Bixby service has stopped' message when I restart my pho e after trying to save the APN settings.
enlli
  • 9.81K
  • 1.45K
  • 2.82K
Message 6 of 17
Re: APN Settings
Configuration settings
text ALL to 789922 to update the mobile internet settings on your phone. Just wait for the configuration message that you will receive then open it from the notification tab and follow the on screen prompt.
Tom_W1
  • 3.66K
  • 199
  • 343
Message 7 of 17
Re: APN Settings
Hi @WG1316, thanks for your post.
It looks like @enlli has beaten me to it - much appreciated!
Please let us know if you need further support.
Many thanks
Tom_W
WG1316
  • 32
Message 8 of 17
Re: APN Settings
Thank you. Will give it a try.
Tom_W1
  • 3.66K
  • 199
  • 343
Message 9 of 17
Re: APN Settings
No problem @WG1316, please keep us updated with how you get on!
Many thanks
Tom_W
WG1316
  • 32
Message 10 of 17
Re: APN Settings
I received 2 sms configuration messages. Clicked and installed one after the other. Saw conformation messages that they had been installed.
Checked APN settings - almost all fields show ' not set'.
MCC And MNC fields show numerals.
Bearer - Unspecified
Mobile virtual operater type GID
Mobile virtual operater value shows 28 followed by a number of zeros.
