Jordans497
Just joined
4G won’t work
My 4G simply won’t work, data doesn’t even turn on and doesn’t give me the icon at the top of my phone, I also can’t call people or send text messages
enlli
  • 7.01K
  • 1.11K
  • 1.97K
Re: 4G won’t work
So it's more than mobile data if you can't call or text.
Can you receive calls a text messages?
Lee_R
  • 2.52K
  • 135
  • 235
Re: 4G won’t work
Hi @Jordans497
Thanks for reaching out. I am sorry to hear you're unable to use your mobile services.
Can I ask if your handset is acknowledging that your SIM is there?  Also have you recently been contacted by Virgin Mobile to advise that you required a SIM replacement?  And does your issue impact you in a specific location only or are you having this issue wherever you are?
Lee_R
