+32 added to numbers when using imessage
Batstonr
Every time I enter a new number to text on my iphone 6s it now adds +32 immediately in front - never used to
seen a similar post on here that didn’t seem resolved. Any answers ?
I’ve toggled Dial Assist - no change
1 ACCEPTED SOLUTION
Accepted Solutions
Thanks for coming back to us @Batstonr.
Please could you turn off your handset, remove the sim card and then put it back in and reboot your handset?
Please could you try and let me know if that helps at all.
Regards,
Steven_L
16 REPLIES 16
Smoggy239
Up to speed
Hi Batstonr,
There are numerous posts about similar problems relating to Belgium ( +32 international dialling code) , the following link might help.
https://community.virginmedia.com/t5/Virgin-Mobile/My-phone-keeps-thinking-it-is-in-Belgium/td-p/446...
Dave
Thanks, I did find that but there doesn't appear to be a solution evident anywhere unfortunately !
Hello Bastonr
Sorry to hear of the iPhone number issues experienced, we appreciate the frustration this can cause and you raising it via the forums.
Were you able to try the following as recommended by enlli:
You need to find your SIM toolkit. I believe it is now located under connections
Select SIM Applications
Select Roaming
Select Select mode
Select National or Virgin
Select International and you are done, go back Home screen to retry
The toolkit will be an app on your phone, you can find it via the search option.
Rob
nope, doesn't work !
To save us going over old ground and suggesting resolutions you have already tried, can you confirm what steps you have tried Bastonr?
Have you spoken to Apple in regards to this also?
Rob
tried the suggestions in the post history that has been highlighted. not tried Apple yet - will do so now
enlli
@Robert_P wrote:
Hello Bastonr
Select Roaming
Select Select mode
Rob
This advice is wrong. When in the UK you have to select NATIONAL
Only use international abroad.
enlli
@Batstonr
The advice given in a previous post about setting the SIM Toolkit is wrong.
In the UK you must set it to NATIONAL
Unfortunately that doesn’t work either
