Tom_Cowan
£2 charges for nothing
When the replacement SIM I was sent didn't work in my old phone, I was eventually given a basic handset. Since I have had the handset £2 charges come off my top up ( I pay as I go) when I haven't been using the handset WHY?
paulchambers061
  • 2.35K
  • 257
  • 437
Problem sorter
Re: £2 charges for nothing
Does it have mobile data switched on? It'll need to be off if you want to avoid charges for internet usage. It'll use data if it's switched on in the background and you'll get the £2 charges daily.
Tom_Cowan
Hi Paul
It is a very basic phone, and as far as I know I don't access the internet with it. It wasn't happening daily.
Also I cant find where on my phone I should check to see if mobile data is or isn't switched on. Sorry I'm an old guy and not that clued up on that sort of thing.
Please help further if you can.
Kind regards
Tom
paulchambers061
  • 2.35K
  • 257
  • 437
Problem sorter
Probably best if you post on here the phone make and model. Then someone will have a better clue what's happening and help you.
Tom_Cowan
The phone is an Enerigzer and my number is [REMOVED]. I don't have any memory added, and only the Virgin SIM I was sent installed.
[MOD EDIT: Personal and private information has been removed from this post. Please do not post personal or private information in your public posts. Please review the Forum Guidelines]
enlli
  • 6.52K
  • 1.04K
  • 1.8K
OK follow this sequence
Goto Menu - Settings - Connections  then unchecked GPRS service
