Tracey9
  • 7
Message 1 of 5
TV virgin box rewind problem
After watching a recorded program we can not rewind live TV to watch the program that was on live TV. Its like we've just switched channel. No rewind TV available at all. It didn't do this before...
Also whern recording a program whist box is on standby we used to be able to just rewind the recording program when box was switched on if program was still on. We can't do this anymore.  Is, something going wrong with the box?  Sometimes have sound issues when rewinding or pausing.
Hope this makes sense and you can help 🙂
japitts
  • 14.4K
  • 1.92K
  • 3.29K
Message 2 of 5
Re: TV virgin box rewind problem
Which box do you have - is it a TiVo or a V6? I appreciate you've posted in the V6 forum but there are some differences here so best to check here
Are you able to pause live TV for, say, 2 or 3 minutes and then resume the channel ok?
Tracey9
  • 7
Message 3 of 5
Sorry its a tivo. Have I posted in the wrong place? 🙁
japitts
  • 14.4K
  • 1.92K
  • 3.29K
Message 4 of 5
Not a problem. After pressing the wrong button initially and doing it in a slightly messy way... I've fixed that for you 🙂
Now then... Are you able to pause live TV for, say, 2 or 3 minutes and then resume the channel ok?
Tracey9
  • 7
Message 5 of 5
It seems to be working okay at the moment when I pause live TV, but sometimes the sound goes and we have to rewind and go forwards a few time until the sounds comes back... Sometimes even change channels. Thank you 🙂
