Tonym62
Sound problem
I have a new tv with Sonos sound bar with my virgin TiVo box
occasionally when changing channels I lose sound and have to flick back and forth between the channels Neil sound is resumed which is very frustrating
i have tried changing the audio setting from Dolby digital to PCM but this actually gives me no sound at all
can anyone help please
Spencer_A
  • 116
  • 18
  • 41
Re: Sound problem
Hello,
Is your soundbar connected with HDMI cable or with an optical cable into the back of the box?
If its connected via optical cable into TiVo box, make sure the TiVo is connected into the HDMI slot which is labeled as Arc (usually HDMI2). If the soundbar is connected via HDMI and not optical cable, make sure that is connected to the HDMI labeled Arc.
Hopefully this helps
Why not try our text messaging service? It's a great way to get help with your services.
Just send your query to 07533051809 and we'll text you back.
We're open 8am - 8pm Monday to Friday, 8am - 5pm weekends.
If my post has helped you at all please mark it Helpful or give a Kudos, thanks!
Tonym62
Re: Sound problem
Sound bar is connected to tv by hdmi and then tv is obviously connected to Tivo box
should I change this?
Spencer_A
  • 116
  • 18
  • 41
Re: Sound problem
Does your soundbar have more than 1 HDMI input available, say to connect the TiVo to the soundbar via HDMI?
If not then ensure your soundbar is connected into HDMI port on your TV labeled Arc (usually HDMI2), then TiVo box would connect via HDMI1, with PCM enabled this should work.
Tonym62
Re: Sound problem
Thank you I will give this a go and let you know
Tonym62
Re: Sound problem
It seems to have worked - thank you very much 👍🏻👍🏻
