Power cable for Vivo box
philmsaunders
Please can I request a new power cable for my box as the power keeps failing on my box due to a poor cable.
Thank you
3 REPLIES 3
Hi @philmsaunders
Are you sure it's a TIVO box?
You can check which box you have on the following page.
https://www.virginmedia.com/care/tv-fault/which-tv-box
Dave
The do's and don'ts.
Yes, it's a Tivo box.
Hi philmsaunders,
Thanks for your post and welcome to the forums. It's great having you on board with us in the Community.
I'm sorry to hear that you're having an issue with the power on your TiVo box.
I have a arranged for a replacement power adapter to be sent to you and you should get this within the next 7 days.
If you have any further issues, pop back and let us know and we can help further.
Kath_F
