Bygone1000
How do I order a power lead for my TiVo box
japitts
  • 19.23K
  • 2.49K
  • 4.4K
Re: How do I order a power lead for my TiVo box
I'm presuming you need a new one because there's a fault with the one you've got? In which case, the easiest way is probably to call VM faults (usual 150/0345 number), report the fault with your existing one and therefore get it replaced.
The specific part might well be an "off-the-shelf" standard piece that you may be able to source yourself, if you could post a picture.
Alex_RM
  • 6.66K
  • 344
  • 501
Hi Bygone1000,
Thanks for posting and welcome to our community 🙂
I've been able to locate your account using your forum information, and can see you you've been able to speak to us regarding this.
If you do still need help with anything please let me know.
Alex_Rm
