when is a gigabit ethernet adaptor not a gigabit ethernet adaptor
on 17-01-202117:02
anyone find that USB ethernet adaptors are generally rubbish and/or bordering on false advertisement.
i have a "gigabit usb ethernet adaptor" made by Plugable. however as it only has a USB2 connection (as it states on the adaptor) then it absolute best it could ever achieve is 480Mbps.
when i run a speedtest using the connection it tops out at around 60MB/s which is pretty close to the 480Mbps limit of the USB connection.
how do they get away with this? Plugable tend to be one of the more "trusted" brands but not with branding it seems!
Re: when is a gigabit ethernet adaptor not a gigabit ethernet adaptor
on 17-01-202117:30
It works with a gigabit connection, so... Presumably a USB 3 jobbie is what you need.
-- The only winning move is not to play. No system is 100% secure Ridicule is nothing to be scared of - Adam Ant The only thing constant - is change. Chris Evans The internet is a series of tubes Windows Update isn't rocket science - if it were, it would work. Unlike Monty Python, spam is never off. Some video posts may contain swearing/inappropriate content for young children
