angelagebbie15
virgin box cutting out
Hi When watching catch up during a programme it just stops and says a cable is unplugged and a fault with the box when no cables have been touched or unplugged I restart the box continue to watch then it cuts out again and then you come out of catch up and there is no tv programmes coming through and I have to restart the box again and sometimes when watching ordinary TV the programme I am watching misses out words I have unable to contact virgin be phone or chat this has been months this has gone on.
  • 23.85K
  • 2.53K
  • 4.33K
Re: virgin box cutting out
Are you watching catch up on a VM TV box? If so is it a TiVo or V6 or 360? If V6 - how do you have it connected to the Hub - by ethernet cable or over wifi?
Or are you watching catch up via a Smart TV - if so how is that connected to the Hub?
Or using some other device to watch?
angelagebbie15
Watching on the older box Tvio all cables have not been touched since installed by virgin it has only started in the last 5 months or so
  • 23.85K
  • 2.53K
  • 4.33K
Go round and remove the co-ax cable connections and put them all back in nice and tightly and see if that helps. The Tivo gets all its catch up via its internal modem and the co-ax - and not via the Hub (like the V6). I believe the connection is thus limited to 10Mbps - but that should be enough for most things - except perhaps 4K video streaming ? But I dont think you would get that error message for that issue - more likely a bad connection.
If its still a problem you will have to call in to see if there is a problem on the Tivo network connection.
