Johan
  • 122
  • 15
Up to speed
Message 1 of 7
terrible speed
Anonymous
Not applicable
Message 2 of 7
Re: terrible speed
wired or wireless connection?
have you tested with another browser as well
DJ_Shadow1966
  • 7.1K
  • 1.36K
  • 2.01K
Message 3 of 7
Re: terrible speed
Hello
One thing I noticed with the speedtest you are connecting to a server that is outside of the UK, can you try with a virginmedia server based in the UK, this could be affecting the speedtest.
Regards Mike
Johan
  • 122
  • 15
Up to speed
Message 4 of 7
Re: terrible speed
spgray
  • 2.39K
  • 139
  • 339
Problem sorter
Message 5 of 7
Re: terrible speed
as previously asked, is this test done on a device that is connected via WIFI or ethernet?
as it says "opera mini" is suggests it's a mobile device.
do a test using an ethernet connected device.
My Broadband Ping - spgray
Johan
  • 122
  • 15
Up to speed
Message 6 of 7
Re: terrible speed
27" imac on ethernet connection
spgray
  • 2.39K
  • 139
  • 339
Problem sorter
Message 7 of 7
Re: terrible speed
ok, it's just that your speedtest image says it was done using Opera Mini, which is a mobile browser.
