dcirulis
  • 7
Message 1 of 8
noise from splitter and tivo box
Hi this has been driving me mad for over a year now. I have a virgin tivo box in bedroom situated near a long radiator the cabling of which runs underneath via a splitter towards my modem. I have been getting a loud ''bubbling'' sound from the radiator. I thought it was air in the system and even replaced the radiator. This morning at 3am I finally discovered hat every time i heard the ''bubble'' the tivo box appeared to take a surge of power. upon switching off the Tivo box the noise that has been driving me bonkers stopped. Any Ideas ???... Could the Splitter be faulty, cable shielding issue?? Any help appreciated before I call for a tech
jb66
  • 12.27K
  • 911
  • 1.78K
Message 2 of 8
Re: noise from splitter and tivo box
It's normal for Tivos to make a drumming noise, they have a very loud Hard disk drive
dcirulis
  • 7
Message 3 of 8
its not a drumming noise it actually sounds like an air bubble that you would get in a radiator like a gloop.....gloop.....gloop...
jb66
  • 12.27K
  • 911
  • 1.78K
Message 4 of 8
I had to turn my TiVo off at night to stop the spooling up and strange noises, if you have broadband you can get a 360mini box which has no hard disk so is almost silent
japitts
  • 12.04K
  • 1.67K
  • 2.58K
Message 5 of 8
Although jb66 is absolutely right, I'd caveat that the 360 software platform is completely different to the TiVo platform and you need to consider a migration to that with your eyes wide open.
I've always found the V6 box is a lot quieter in general operation (even with the HDD) than the TiVo.
  • 8.46K
  • 675
  • 1.51K
Message 6 of 8
FYI splitters are totally inert devices and cannot ever cause by noise.
Graham_A
  • 16.53K
  • 2.32K
  • 7.06K
Message 7 of 8
VM do use some powered splitters where signal strength issues exist.
However, the ones that I had in place a while back did not cause any noise issues.
________________________________
Graham
I'm a Very Insightful Person, I'm here to share knowledge, I don't work for Virgin Media, I'm a VM customer. There are no guarantees that my advice will work. Learn more
nodrogd
  • 16.8K
  • 1.97K
  • 4.08K
Message 8 of 8
You shouldn't get noise from any passive device in the coax runs (splitters, attenuators, isolators). Active splitters & HDUs are easy to spot as there has to be mains fed into the system somewhere on the customers property.
VM BB TV Landline PAYG mobile. Freeview/Freesat HD, Tesco Mobile. Customer since 1993
