pietropete2020
Message 1 of 7
cable
Have just got a new Samsung 4k tv and need a cable to load from the tvio box to the tx and i am not too sure what cable i need to get. Any help would be most appreciative
jb66
  • 12.43K
  • 925
  • 1.83K
Message 2 of 7
Re: cable
The cable is called a HDMI cable
spgray
  • 2.39K
  • 139
  • 341
Problem sorter
Message 3 of 7
Re: cable
would have thought you'd already have an HDMI cable? the tivo comes with one, and you would have been using that cable with your previous TV?
My Broadband Ping - spgray
Graham_A
  • 17.28K
  • 2.47K
  • 7.36K
Message 4 of 7
Re: cable
Not necessarily, if it was on old TV it may have been connected to the TiVo via a scart cable.
________________________________
Graham
I'm a Very Insightful Person, I'm here to share knowledge, I don't work for Virgin Media, I'm a VM customer. There are no guarantees that my advice will work. Learn more
spgray
  • 2.39K
  • 139
  • 341
Problem sorter
Message 5 of 7
Re: cable
jeez how old?
regardless, the tivo ships with an HDMI cable in the box, doesn't it?
pietropete2020
Message 6 of 7
Re: cable
Thank you for your quick response and yes my old tv was connected by a scart cable and the new one doesn't have space for one. That was why i was asking
spgray
  • 2.39K
  • 139
  • 341
Problem sorter
Message 7 of 7
Re: cable
even if the new TV did have a scart connection you wouldn't want to be using it anyway.
