on 16-10-2023 14:49
What do virgin normally use for the cable entry point? Its just on my daughters new build property they have installed adjacent to the front door (200mm) a hideous brown plastic box approx 150mm x 150mm and 100+mm deep for the termination point!
Openreach and Hyperoptics have both installed a neat small thin grey cable entry point!
16-10-2023 14:59 - edited 16-10-2023 15:11
Virgin uses copper coaxial cables to distribute its services within the property. The unit contains the powered ONU that converts the incoming fibre to RF technology to drive Virgins DOCSIS Broadband hubs & Cable TV boxes. This is what it looks like inside:
16-10-2023 15:02 - edited 16-10-2023 15:07
VM's wall boxes look like this
The larger one on the right is used for fibre connections and a fibre converter.
These are the standard sizes although I think some are available in a grey/white colour.
on 19-10-2023 22:11
on 19-10-2023 22:27
They actually don't put the ONT outside anymore, the omnibox is rediculous I agree but is normal
