  • 7
MathewPope
Wrong Cable Installed
So I ordered virgin media 350 and weekend calls and on the website it says that they would provide my telephone services over your broadband connection. 5 days later kelly comms turned up and ran my hfc cable from the distribution cabinet about 25 metres down the road to my house but I read online that the telephone services over broadband would only work with FTTP. Have kelly comms installed the wrong cable ?
  • 7
MathewPope
Re: Wrong Cable Installed
  • 4.98K
  • 350
  • 846
Roger_Gooner
Superstar
Initially VoIP phone was provided only over fibre but it's now done over coaxial cable as well.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 7
MathewPope
Okay thanks for some reason the cable that’s installed now has 2 cables like a double barrel shot gun one has the hfc one has the normal copper telephone wire
  • 4.98K
  • 350
  • 846
Roger_Gooner
Superstar
Yes, it's known as siamese cable with coax bonded with copper.
  • 13.53K
  • 1.05K
  • 3.16K
afaik thats all they install - just standard cable - the telephone side of the cable will not be used if the phone is via the BB
____________________
Tony
