on 17-01-2023 20:08
Hey guys, wonder if anyone could give us a hand. My wife works from home and opens up the same web site every day on our wifi network and every day it works fine. Today it is not opening at all, on any device in the home on wifi. Every other web site we go onto works fine and what makes it a little more strange is that the second we go onto mobile data it opens and works fine.
Please help if there is any.
Thanks in advance
Warren
on 17-01-2023 22:57
Can you post a traceroute of the failing website, from the failing device?
on 17-01-2023 23:19
Do you get an error message? If so what is it?
on 17-01-2023 23:29
Hey there. Cant say I would know how to do that to be honest.
on 17-01-2023 23:31
No error message at all. Page or linked pages to the website wont even start opening
on 18-01-2023 08:14
What is the address of the website ?
Perhaps the issue is the same for all VM customers - we saw that yesterday where a commercial website had been blocked in error.
If you using a Windows PC you can use the "Snipping Tool" to take a screen shot ...
then switch back to this forum and Paste ( Ctrl V ) the image in under your test.
You will get an image inserted like this ...
on 24-01-2023 00:19
In Windows open a Command Shell (press Windows key + R, type cmd and then press Enter key), otherwise open a Terminal, and enter the following command but replacing example.com with the site URL causing issue:
curl -I example.com
Post the resulting output here; make sure to redact anything you do not wish to post in public?
Have I helped? Click Mark as Helpful Answer and solved, or use
Kudos to say thanks
on 08-02-2023 09:01
This issue might be caused by a number of reasons:
Internet Connection: The issue could be with your home Wi-Fi network, as other websites are working fine. Try resetting your router or modem to see if it fixes the issue.
DNS Resolution: The website could be down or the domain name server (DNS) could be having issues resolving the domain name to an IP address. Try using a public DNS server like Google's (8.8.8.8) to see if it fixes the issue.
Firewall or Antivirus: Your firewall or antivirus software might be blocking the website. Temporarily disabling these could help you determine if that is the issue.
A host's file could be blocking it, or your IP or the URL has been put on a blacklist.
