M1LOU
Message 1 of 5
Voip SIP ALG Problems with Hub 3
Hi has anyone that has been having problems with drop outs, one way audio or chatter using VOIP with a Hub 3 put it in modem mode and used a different router. If so did it clear the problem and what router did you use?
Regards M1LOU
Tags (2)
Roger_Gooner
  • 6.54K
  • 475
  • 1.14K
Legend
Message 2 of 5
Re: Voip SIP ALG Problems with Hub 3
Some years ago I used a TP-Link Archer C7 and disabled SIP ALG.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 15.94K
  • 691
  • 1.56K
Message 3 of 5
modem mode clears all problems.
Anonymous
Not applicable
Message 4 of 5
never had a problem in router mode with the hub 3.
but as a VOIP engineer.... god i hate SIP ALG!!!!!
M1LOU
Message 5 of 5
I’m a Radio Amateur using IRLP that stands for Internet Radio Linking Project basically a radio system linked to other radios around the world using the internet. For this to work then the router needs to forward ports in the router one set of ports are in the range of 2072 to 2094 UDP, 2074 and 2073 are the ones that fail (not all the time) but for some reason 2093 is totally blocked this then relates to one way audio and other problems. It does look like I am going to have to put the Hub 3 into modem mode and use a different router just not sure which one to use
