Rajmi5
Message 1 of 5
Virgin media cable cut through
Accidentally cut through the virgin media cables in the front garden. And I cannot get hold of customer service or been able to advise we are without Internet connection.  I have called over 10 times and have been on hold of over 1hour a couple of times. I'm not sure what else I can do.
Anonymous
Not applicable
Message 2 of 5
Re: Virgin media cable cut through
Contact them at 8am when the lines open.
Rajmi5
Message 3 of 5
Thank you,  Will try again in the morning at 8am. Fingers crossed.
SCA1972
  • 5.89K
  • 662
  • 2K
Message 4 of 5
If you can't get through on the phone then VM are recommending you send a text to 07533 051809 describing the issue and you should get a response, but it may take a day or two at present. This is a text only service, it does not support voice calls.
https://community.virginmedia.com/t5/Digital-life/When-and-how-to-use-our-messaging-service/ba-p/425...
______________________
Scott
My setup: VM TV box, M350 Fibre broadband with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
Rajmi5
Message 5 of 5
Thank you for this.
In the end I still did not get through to anyone by phone in 3days of trying and holding for over 30mins to an hour. But managed to book an engineer via there online services, and was only out of Internet for 4days.
I did receive a call back on the day the engineer was coming and more a sales pitch to refer a friend for £50.
Anyway all done,the wire is patched up in a bright orange connection box and left unsecure placed across on the driveway and garden they did not bury the wire and I was told to do it myself.
But thank you and I appreciate you giving me the details, I'll keep the text number for next time if needed.
