Kated
Message 1 of 12
Virgin cable cut through
Trying to get through to virgin media, says closed due to COVID-19!
anyone know how to go about reconnecting an accidentally cut through cable outside
Rely on all the services as My husband in extremely vulnerable list and shielding
help thanks 😊
spgray
  • 2.39K
  • 139
  • 338
Problem sorter
Message 2 of 12
Re: Virgin cable cut through
CS isn't closed, it's open and calls are being taken.
you'll need an engineer visits, so best to try CS again.
My Broadband Ping - spgray
Kated
Message 3 of 12
Thank you
managed to get through niw
hoping it’s not going to be expensive
Steven_L
  • 4.12K
  • 304
  • 399
Message 4 of 12
Hi and a warm welcome to the community Kated
Glad to hear that you have been able to get an appointment booked in to get your cable repaired. The visit will be free of charge to get this repaired.
Steven_L
Kated
Message 5 of 12
That’s good to know
going to be two weeks for an appointment though🤔
thought it may of been sooner
spgray
  • 2.39K
  • 139
  • 338
Problem sorter
Message 6 of 12
you will have got the earliest appointment available.
Steven_L
  • 4.12K
  • 304
  • 399
Message 7 of 12
I have checked this and as @spgray said, you have been given the first available appointment for this to be done, I'm sorry that it can't be any sooner.
Steven_L
LittleMick73
  • 4.81K
  • 501
  • 822
Superstar
Message 8 of 12
Your very lucky you are not being charged £99 which is the usual case with non fault call outs
Kated
Message 9 of 12
Not sure if I am being charged for sure
As far as I’m concerned its their fault anyway for not burying the cables under the garden
spgray
  • 2.39K
  • 139
  • 338
Problem sorter
Message 10 of 12
you don't get charged for cut external cables.
a cable cut is a fault, non-fault is for any work needing done that is over and above a standard install.
