on 29-11-2022 14:40
We have an outhouse separated by 5 metres from the main house with also an entirely separate electricity connection. Our virgin router is in the main house with very poor reception in the outhouse. We have a separate virgin cable connection to the outhouse as we used to have a separate tv setup there in the past. We want to install a new alarm system in the outhouse that runs on Bluetooth connection. How can we boost reception sufficiently for this to work or possibly connect directly to the currently unused internet cable . I understand Virgin will not allow a second router ( without significant extra monthly charge). HELP 🧐
Answered! Go to Answer
on 29-11-2022 21:05
You cannot use the VM coax at all. One possible solution:
For point 4) other options may be available, but I only have Apple kit. Other may be able to help here.
on 29-11-2022 21:05
29-11-2022 21:22 - edited 29-11-2022 21:23
on 30-11-2022 01:09
You may find this useful:
on 30-11-2022 16:46
As you seem to already have an Ethernet cable to the outhouse you can connect it to the Ring base station. If you need WiFi as well then connect the cable to a gigabit network switch and the base station and a wireless access point (for WiFi) to the switch.
on 30-11-2022 16:49
on 30-11-2022 16:52
