  • 11
danm77
Message 11 of 22
Re: Upgraded to VIVID 350. Homeplug/powerline speed not going above 190mbps
Here’s a WiFi Speedtest from December when I still had VIVID 150.
165mbps download speeds:ED455145-96FA-40C8-ACEC-2F85B8A67D83.png
Now that I’ve upgraded to VIVID 350 it maxes out at 190mbps on homeplug WiFi.
  • 4.88K
  • 341
  • 830
Roger_Gooner
Superstar
Message 12 of 22
An individual 165Mbps Speedtest proves little. Your 190Mbps is consistent with your 350Mbps download speed and the laws of physics. You will be disappointed if you think you'll get 350Mbps or more from homeplugs. The only reliable way to get good speeds far from your hub is with an Ethernet cable and a suitable wireless access point.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 11
danm77
Message 13 of 22
It wasn’t a one off, I regularly got WiFi speeds at or near the advertised 150.
I’m not wanting or expecting it to exceed 350 now, I’m just curious as to why it’s hitting a ceiling of 190 with a 350mb broadband package when previously it would get to the advertised speed regularly when I was on vivid 150.
  • 10.53K
  • 671
  • 1.41K
jb66
Message 14 of 22
Im not sure how you are not getting this, you could have 100000000000000mb internet but your home plugs are too slow to pass more than 190.
165mb is lower than the 190 limit your homeplugs can run at
  • 11
danm77
Message 15 of 22
I do get what you’re saying but where is your evidence that homeplugs don’t go above 190mbps? I’ve never seen anything to suggest that 190 is the max. If you can point me to some evidence of that then please do so.
The devolo homeplug I have is capable of up to 1200mbps - that’s a theoretical speed I know, but I would not expect 190mbps to be the limit.
  • 10.53K
  • 671
  • 1.41K
jb66
Message 16 of 22
  • 11
danm77
Message 17 of 22
Well if you read this review of the devolo magic 2, which is the model above mine with theoretical speeds up to 2,400mbps, the reviewers achieved 456mbps when the adapters were placed in the same room as each other: https://www.techadvisor.co.uk/review/powerline-adapters/devolo-magic-2-wifi-powerline-mesh-wi-fi-rev...
  • 10.53K
  • 671
  • 1.41K
jb66
Message 18 of 22
If av1200 powerlines get 190 it's quite probable that av2400 get 190x2= 380mb.
Again around 10-20% of advertised speed
But at those prices I'd go mesh
  • 11
danm77
Message 19 of 22
True. Would you not recommend the devolo magic 2 as it has mesh with a powerline backbone?
  • 10.53K
  • 671
  • 1.41K
jb66
Message 20 of 22
The virgin powerlines or 'boosters' actually have mesh technology and work well, I've never seen a av2400 powerline in real life but sounds promising.
