swinterburn
Message 1 of 5
Technical Help / Support not accessible
I have two issues:
1. I believe there is some restriction on my Virgin Media broadband service that is preventing my mic being heard when I make a Microsoft teams call, but doesn't if I join someone else teams call. When using my mobile phone's 4G connection as a wifi hotspot this allows me to make teams calls without issue, so I believe the problem lies in the Virgin Media broadband service.
Any help or insight into this would be much appreciated.
2. I would like to upgrade my existing Virgin Media Super Hub 2ac to either the Hub 3 or Hub 4 but have been unsuccessful in contacting anyone from Virgin Media in order to do so.
Please can someone from Virgin respond to this?
spgray
  • 2.39K
  • 139
  • 339
Problem sorter
Message 2 of 5
Re: Technical Help / Support not accessible
the virgin connection can not cause any issues with your microphone being heard.
My Broadband Ping - spgray
swinterburn
Message 3 of 5
I get that the connection isn't the issue, but more like an inherent router/ISP setting or restriction perhaps?
spgray
  • 2.39K
  • 139
  • 339
Problem sorter
Message 4 of 5
unlikely. all teams is seeing is an internet connection, there isn't anything specific to audio/microphone traffic.
what troubleshooting have you done other than try it on a mobile hotspot?
MrHalfAsleep
  • 2.48K
  • 71
  • 974
Problem sorter
Message 5 of 5
 https://support.microsoft.com/en-us/office/my-microphone-isn-t-working-in-teams-666d1123-9dd0-4a31-a...
The only winning move is not to play.
No system is 100% secure
Ridicule is nothing to be scared of - Adam Ant
The only thing constant - is change. Chris Evans
The internet is a series of tubes
Windows Update isn't rocket science - if it were, it would work.
Unlike Monty Python, spam is never off.
Some video posts may contain swearing/inappropriate content for young children
π
