ultimatealanjuk
  • 8
Super hub 2 and Hub 3 power supply - the same?
Can I just use the power supply from my Super Hub 2 in my Hub 3? They have the same spec 12V 2.5A so that shouldn't be an issue but wanted to check. If I can, it would save me having to empty and remove a fitted unit.
Thanks.
Andrew-G
  • 6.07K
  • 1.07K
  • 2.56K
Re: Super hub 2 and Hub 3 power supply - the same?
Worked fine for me.  Low voltage DC power units are commodity items, so if specs match go ahead (and in my experience also worked OK with a similar spec Casio keyboard PSU).
For future reference, it might be worth considering that PSUs don't last for ever, and building them in is a bad idea.
ultimatealanjuk
  • 8
Thanks. It's not too difficult to get to the PSU, just a bit of a bother to empty it first then pull away from the wall. Might look at cutting a hole in for quicker access.
  • 8.12K
  • 649
  • 1.42K
Basically you can use any good quality power supply as long as you follow these rules;
Must be the correct voltage
Must supply the same or greater amps.
Must not supply lower amps.
