proxymc
Studio Speakers via Audio Analog Converter to TiVo
Hello,
I was trying to hook up my active studio speakers with TiVo via optic cable and decent Digital to Analog Audio Converter. This setup works perfectly fine for Playstation 4 but when I am trying to switch it to the tv box I am getting only a white/clicking noise. My only guess is that TV box accepts only digital signal. Is that true?
LittleMick73
  • 4.94K
  • 513
  • 840
Superstar
Re: Studio Speakers via Audio Analog Converter to TiVo
Yes
Roger_Gooner
  • 6.54K
  • 473
  • 1.14K
Legend
When you say "switch" do you mean a TOSLINK switch?
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
proxymc
Yes. Well, my converter has 4 toslink outputs and I can switch between them via remote control. However, this is irrelevant because I tried plugging only Tv Box and I am getting only a noise. I believe it has to be a digital signal, which is a bit bizarre, as Playstation 4 works only with analogue.
Roger_Gooner
  • 6.54K
  • 473
  • 1.14K
Legend
Any converter can fail. I suggest you look at upgrade options for audio delivered over HDMI such as a soundbar or speakers driven by an AVR.
Anonymous
Not applicable
Have you checked the optical output settings?
It may need setting to PCM.
