randombeats
  • 59
Sound bsr
  • 6.09K
  • 512
  • 1.57K
Re: Sound bsr
None of these seem to be above 2.1 channel?  Personally I would bite the bullet and get at least a 5.1 channel surround system.
LittleMick73
  • 5.39K
  • 547
  • 924
Superstar
Re: Sound bsr
Hi I'm with Adduxi spend a bit more and get a proper 5.1 system as I'm sure after a while you will be dissatisfied with inferior sound. Regards Micky
